I am not a HI FI GUY...I just purchased a Samsung 5063 HD-DLP....I am blown away...I had been watching a 1995 Sony 25" Trinitron from 17-25 feet away...
Now I am hooked on TV!
So...I have to get a surround system.
Here is my question.
Is the Denon 1905 worth getting or should I swallow it and get the 2905?
Again, I am clueless. Thanks!
LongTimeWolf
any help?
Really need an entry level Reciecer with the potiential for growth...
HELP
Probably going to use Paradigm speakers...7 or 5
edster922
If you're mainly doing TV and DVD you really don't need a super duper receiver.
I'd go for the Pioneer 1014 ($400), get a cheap progressive scan DVD like the Toshiba 3960 ($50) and spend most of your budget (60-70%?) on good speakers and a quality subwoofer ($400-600).
A lot of guys recommend the Paradigms, you should be happy there.
There are multiple posibilities for an entry level receiver, edster has you on the right track with the Pioneer. I know many people are not, but I am a bit partial to Sony receivers having owned three and will soon be in the market for a fourth. Check out the ES line of Sony and see if it fits your needs...if not there are plenty to choose from like the 1014 that was mentioned.
