Bass too much
Username: Erexkiss
Post Number: 12
hi everyone, my problem is that there is too much bass going from my speakers (infinity entra three), even though i set the bass knob on my receiver (Onkyo TX-SV 424) to the minimum, and the bass part of the equalizer on winamp to the minium. Yes, i run my music through my laptop. I am in desperate need of help, can someone please help me what could be wrong with my setup?
Thanks a lot!
Username: Erexkiss
Post Number: 13
sorry my mistake, it should have gone to the speaker or receiver topic.
Username: Adamx12
Henderson, CO USA
To me most of the EQ are set in happy face or sin wave. This should give you a good sound. Just like most musician set their EQ same way.
Username: Thx_3417
Post Number: 844
Don't use boosts ever increase the bass output, or the other frequencies as well set the amplifier, level to higher to compensate for the loss, never boost the settings on the EQ always use cuts on an EQ.
hi everyone, i hav the toshiba qosmio laptop, with harman/kardon speakers, but these speakers dont give out any bass, i tried going into the advanced options under the audio prefrences, but the bass and treble options are locked, can someone plz tell me how to boost the bass on my laptop? thanx
Username: Anubis
Birmingham, West Midlands England
Post Number: 34
You can't really expect a computer to do the same job as a seperates. If you're bothered about EQ levels, you're using the wrong type of equipment.
Equalisers generally destroy the balance in levels. Consider what a mess a digital one makes. Try disabling all forms of EQ and use your amp's contols to compensate, as Andy says. I've found line-interconnect choices makes all the difference and that they're most apparent between computer and amp.
A/V
Need to Register?
Forgot Password?
Enable HTML code in message
