I am looking for a home theater receiver for 100% movies. The room size is 12' x 20' x 8'. The speakers will be Mirage Nanosat, Omnisat Micro or Orb Audio (I am currently leaning to the Mirage speakers, however I have more research and listening to do).
I was thinking about the following receivers (in no particular order):
I chose these based on features, availability, and price. I am only concerned for movie playback, however I would like to be able to plug it into my integrated amp to use as a tuner.
Among those that you have mentioned I would go with the Marantz. Just sounds better!
edster922
I agree with Arthur but question the need for such a high quality receiver and speakers if you're doing 100% HT...unless you like cranking up the volume of dramas that have classical or jazz soundtracks, the wham-bam-kaboom sounds of most Hollywood blockbusters don't really require a whole lot of finesse and plus the Dolby Digital soundtracks are usually mixed so well as to be very forgiving of decent-but-not-great quality gear.
Just my 2 cents, if you're money's just burning a hole in your pocket then who am I to stop you?
jatay81
For the speakers I was looking for something small and forgiving of placement. For the receiver I do not care so much about the sound as I do the processing. I have a 2-channel system that I will use for all critical listening.
I do not have any experience with home theater, so all recommendations are welcome.
edster922, what speakers would you recommend that would be cheaper for a 5.1 system (I already own a REL Storm III sub).
edster922
I'm not familiar with the speakers you listed nor your subwoofer, but once I did hear a pair of Mirage towers at someone's house which sounded horrible. (That might've been poor setup plus they were using an Onkyo 8211 or 8511 which is not very good for 2-channel music anyhow.)
I'm not exactly clear on what you mean by "forgiving of placement"---I'm not sure there is such a thing, proper placement is ESSENTIAL with any type of speakers. How do you plan on positioning these speakers in relation to your listening/viewing position?
Since this will not be your critical music listening system, I'd go cheap---a $230 JVC RX-F10 all digital receiver, a $300 Onkyo 602, or a $400 Pioneer 1014. All three should have plenty of sound processing options, especially the Onkyo and Pioneer.
