H/K AVR 430 and sub question
Username: Svendehot
Kalamazoo, MI USA
Post Number: 11
Hello,
I recently purchased the 430 and I have it hooked up to some, I know it sounds idiotic; Sony mini hi fi speakers at 6-16 ohms. I am going to purchase some new speakers really soon. But I also hooked up a pioneer sub (100 watts 8inch cone) to the line level output. But, the out put of the sub is next to nothing when I listen to music. I have turned the sub level to +10. I have it connected with a digital coaxial cable. I want you guys to tell me everything I need to know like if I should disconnect the speakers and just turn the unit off until I buy new speakers and about the sub!
Thanks, and please do not be modest I would really appreciate your full input! Flame ON!
Username: Project6
Post Number: 2858
Is it a powered sub?
You should hook that up to the subwoofer output (or LFE) of the HK430. Then when you do the speaker set up, turn the subwoofer to ON.
Username: Project6
Post Number: 2859
It should be in the back under "pre-outs" subwoofer. On the lower left had corner of the back of your receiver. Then follow the set-up configuration on your manual. Page 9 of your manual, number 4.
cheers
Username: Svendehot
Kalamazoo, MI USA
Post Number: 12
Yeah man, i have done that it is throught the sub preoutput. the purple one. the sub is an active subwoofer. the sub settings are set to this. speakers large, sub as l+r/LFE. i mean, is it possible for there to be a problem with the in put of the sub or possibly its frequency response spl when it comes to it being less than 100 hertz?
thanks ben
Username: Stur
Midland, Texas USA
Post Number: 7
It's possible that youy have a bad connecting cable. I had this once .. with a brand new cable.
Username: Project6
Post Number: 2866
set the speakers to small. Does the subwoofer have its own volume or gain control? Most powered subwoofers have their own volume controls.
And check your cable, like stu-r wrote.
