5.1 Surround - Rear Speakers Do Not Work
I just discovered that only 4 of my 6 speakers work (sub,center,left,right). I have no where to connect the rear speakers or sub, there is only 1 jack for the front left and right and center. How do i fix this?
Username: Touche6784
Post Number: 232
what kind of reciever/setup do you have? cant really help if thats all the information that you give. im guessing you have a stereo reciever. give more info.
The speakers are plugged into the sub, which has 1 of three connections plugged to my computer, i am only able to plug in the connection for the frontleft, frontright, and center speakers, the other connection is for the rear speakers, and the third is for the sub. Im a complete newb with this -_- My question is how would i plug in the rear speakers and sub connection to the computer, if there is no jack/outlet for it?
tommacb2k
you need a 5.1 sound card for your pc.this will enable you to add up to 5 jacks into the computer.tom
