Heat tolerant speakers for sauna?
Any less pricey options to the Sonance Symphony Extreme for in ceiling installation in a 6.5 x 7 x 7 foot sauna? I can find a lot of "weather resistant" options, but I can't tell if they would tolerate that degree of heat (130-170F).
Surely all those sauna kits with speakers included are using something a few cuts below Sonance. Any help appreciated....I need to decide and install asap.
Username: Paul_ohstbucks
Post Number: 452
Any speakers designed for boats or outdoors should do. Of course, sauna ratings arent listed in the specs, so I wouldnt recommend spending much.
A small set is all you need in that space, so durability isnt a big concern. It wouldnt take much to fill your sauna with booming sound.
Good luck.....
