Will 100 watt speakers work ok with a 120x6 amp or will they fry?
asdsfhgfdsa
that will work just fine (most of the time) just dont put the volume way up. also check the resistance between the speakers and amp. if the amp has a lower res than the spkers(usually 8-ohm) it should be just perfect.
