Changing my linear turntable belts????
Username: Nnnnicole
I have a Sharp VZ-3000 Front loading turntable/stereo system. I cant figure out how to get to the belts to change them.
Any input would be great.
Username: Jim_mcbob
Post Number: 44
you're sure it's belt drive?
Yet another Bob
I've done one of these. You have a lot of dismantling to do! you have to get the turntable assembly completely separated from the rest of the machine and then remove one more bracket. Some serious work!
Username: Prosorth
Saint John , New Brunswick Canada
I have my VZ-3000 open now for needle change and cleaning. Changing belt is not that difficult. Need instructions?
NEED INSTRUCTIONS TO REPLACE BELT IN VZ-3000 VERTICAL PLAYER CAN YOU HELP?
