I'm moving to a loft - around 1500sqft and need to set up a new system to cover as much of this long, skinny space as possible. I'm thinking of getting a NAD352 or NAD 370 amp and running 3 sets of speakers off it. But I'm trying to keep the speakers at under $300 a pair. I was considering Polk RTi4's or Niles OS 6's. I'm planning to put them on brackets near the ceiling - so I guess I'm looking for bookshelves. 1) Recommendations for speakers? 2) Should I wire them mono to keep the sound consistant? 3) Would this be a good amp choice?
I'm a newbie - so treat me gently
Jasdeep
Dear Andy,
I will recommend you Tannoy Fusion 2 or Tannoy Reveals. Do audition them.
Why do you want six speakers in your room that too wired in mono.
Whats your room size and ceiling height. Do you have false ceiling. If you have problem keeping speakers on floor, You can use good quality ceiling speakers with a ceiling subwoofer.
