Bronze Member Username: FablePost Number: 15 Registered: Jun-04 | I don't want to spend over $100 for the DVD-A cable so please tell me where I can buy 6 cables for my DVD-A player. Thanks. |
trying Unregistered guest | Try the Dayton Audio cables at http://www.partsexpress.com Very good quality at around $12 each. |
Bronze Member Username: FablePost Number: 19 Registered: Jun-04 | Got the Dayton RCA cables. They are solidly built and work perfectly great. Before the Dayton, I used the cheap RCA (the red/white pair that come free with any DVD player purchase) and my DVD-A sound dull and noise. When I hooked up the Dayton RCA, the sound is clear and cleaner. In addition, I can't really tell the different between the Dayton and the Monster in 2 channel music. The Monster cost 5 times as much (to my whim last year I spend money on Monster cables). I begin to think Monster is a ripped off now. So for any of you thinking of spending big $ on Monster cable, think twice. I have their top of the line component and optical cables and they don't work better than my $20 component and a much cheaper optical cable respectively. I can't tell the different between them in both video and audio. Good cable do make a different to your system but they don't have to be expensive. Just don't use the free cables come with your purchase; any decent made cable such as the Dayton will work just like the $90 Monster cable. I've learned it the hard way. Thanks for recommending a good source. |
Bronze Member Username: ClaudermilkPost Number: 88 Registered: Sep-04 | LOL, you just hit on the collective opinion of Monster around here! |
