Bronze Member Username: YamahaboyOrland Park, Illinois USA Post Number: 50 Registered: Jul-04 | hey everyone, as some of you might know i have had some amp problems with my pioneer head unit. it has been reading "amp err" after a second or to after turning on. I am going to buy a new reciever and dont know exactly what to buy. i have no more then $200 to spend and dont wanna buy something crappy. i was looking at Eric |
Bronze Member Username: YamahaboyOrland Park, Illinois USA Post Number: 51 Registered: Jul-04 | does ANYONE know???? |
Silver Member Username: KanoPost Number: 409 Registered: Oct-04 | Sony makes crap audio products IMO. High distortion and a thin tinny sound plagues the low-end models. While the ES line performs better, I find the cost/performance benefit doesn't add up when comparing to competitors. The Pioneer 1014Tx is a stronger performer within the same price range. If you found your previous Pioneer's sound too flat take a look at the Yamaha HTR-5790 or the RXV line preferably. Marantz also makes good receivers at that price point. Take a look at the 4400. |
edster922 Unregistered guest | I agree with Kano, non-ES Sony receivers suck big time. Their DVD/CD players aren't too bad though for the money. If $200 is your absolute limit then you'd be better off going with a refurb Onkyo 502 from ecost.com for $190. The Pioneer 1014 would be much better but around $350-400. |
Bronze Member Username: YamahaboyOrland Park, Illinois USA Post Number: 52 Registered: Jul-04 | yeah 200 is about it because my parents are going to replace the one that is broke (it was there and we switched recievers) this is the equip i got https://www.ecoustics.com/electronics/forum/system-showcase/68928.html |
edster922 Unregistered guest | OK, then do the Onkyo, it'll still be way better than a Sony. |
