Speaker Polarity
kta
Just got a rx-v2500 to power Kef Q7 fronts, Q4 surrounds, Q9c centre and Q95c rear center (about to upgrade to 2 KHT 2005.2). Running through the ypao, both sets of Q7 and Q4 both the wiring show as REV. The wiring is correct. Swapping the polarity, the ypao is then correct but the wiring is wrong. Any ideas??
Username: Paul_ohstbucks
Post Number: 292
Just ignore the incorrect YPAO reading so long as you're sure they are correct. The YPAO said one of my speakers were reversed too. I double double checked my connection and it was correct.
I read a review by audioholics, and it happened to the tester too. It's the only bug that I've found in the setup process.
