Quick Marantz question- maybe edster922???
jimboston22
I just picked up the SR5400. It really is a fantastic unit. I have one question. The DVD codes in the manual do not work for my DVD player. I have the new Yamaha DVC750. The yamaha codes do not work, maybe they are old. Does anyone know where I can get a new code for Yamaha DVD players?
I emailed Marantz 3 weeks ago, but received no response.
edster922
ooh, I dunno...I never got around to programming the remote to work on my other components, so am still using 4-5 different remotes on my coffee table! : )
I've never tried to email Marantz but did call them once and was able to talk to a tech support person after a not too long wait, so maybe try that route too.
Username: Shahrukhd
Mumbai, Maharashtra India
Post Number: 27
Jimboston, I had a similar problem with my Marantz SR4400. It couldn't read the code of the DVD player. But there's a way you can find out what the code is by the blinks on your remote control. See the manual under "reading the device code". It's right after they tell you how to program an unlisted player.
