Username: Sunnygem AmsterdamNEtherlands
Post Number: 1 Registered: Mar-05
Monday, March 07, 2005 - 15:50 GMT HI, How can I connect my Ipod Mini to the Yamaha receiver ? Pl advice. Fyi.. I alreay have a home surround system with Yamaha receiver and Bose Speakers. thanks in advance, sunny
Username: Kano Post Number: 390 Registered: Oct-04
Monday, March 07, 2005 - 19:54 GMT You eiter use the dock, which will amplify the signal and is intended to be connected directly to speakers, or use the RCA package that is sold seperately (better)
Username: Tevo Chicago,
IL
Post Number: 99 Registered: Feb-05
Tuesday, March 08, 2005 - 02:30 GMT If I am not mistaken, the Dock has a line level out. A 1/8-mini to RCA cable will do the trick. As Kano points out, there are also adapter packages that allow you to obtain line-out without using the Dock. The headphone out at the top of the iPod is not line level but either way, the signal passes through the iPod's EQ.
Post Number: 2 Registered: Mar-05
Tuesday, March 08, 2005 - 08:48 GMT Thanks again for the advice :-))
