New member Username: Morrow21Post Number: 1 Registered: Mar-05 | Recently got a Yamaha 5760 receiver, looking for a very entry level sub. Looking at three models: Yamaha YST-SW315 JBL E150P Velodyne VX-10 Mainly watching movies, but do enjoy listening to music of all kinds as well. Any suggestions on these or any others I should look at would be appreciated. |
New member Username: Morrow21Post Number: 2 Registered: Mar-05 | Also found the MTX SW2 at CC, but know nothing about it. anyone? |
New member Username: BrandzipHouston, Texas USA Post Number: 6 Registered: Feb-05 | Here is another possible choice with great bang-for-the-buck value. HSU is a very well respected, high quality brand. http://www.hsustore.com/stf1.html |
New member Username: Javmo200GB, Michigan Post Number: 2 Registered: Mar-05 | B&W AWS 750 the best -I love the sound specially working with Rotel 1067 |
Silver Member Username: PetergalbraithRimouski, Quebec Canada Post Number: 324 Registered: Feb-04 | So your budget is less than US$200? I'm thinking the B&W AWS 750 is over budget! :-) The STF-1 is still over budget at $299 but it's probably worth it to spend a bit more than $200 for a sub. I'd go for that if you can swing it. |
New member Username: Javmo200GB, Michigan Post Number: 6 Registered: Mar-05 | Wher did he made mention of his budget? I do agree for a "very entry level" ASW 750 is a bit much. I also agree with the STF-1--300.00 but good. HSU is 699 believe still a bit much. |
