ricka44 Unregistered guest | I am a novice putting a home theater system together. I have only 12" of height for my sub. Is there one available at that size or is it OK to place a sub on it's side? thanks |
Silver Member Username: JamespMansfield , TX USA Post Number: 105 Registered: Apr-04 | If that is all the room you have look into the sunfire true sub jr, velodyne spl-800 and def tech supercube II. The hsuresearch stf-1 can be laid on it's side and far cheaper than any of the above. The STF-1 will give comparable, if not better performance than the ones listed above. |
Silver Member Username: JamespMansfield , TX USA Post Number: 106 Registered: Apr-04 | Here is a good review on the STF-1 http://www.hsuresearch.com/sensible_sound_oct_04c.pdf |
