thanks for your help Mike-Jose. But no, that's not it. I know my buttons inside and out. something is screwed up with the receiver. I even checked the fuses inside of it, and they're ok. So I don't know, I thought that Onkyo will never crap out.
Mike-Jose
Did you also run the setup (the one where you adjust the db level of each speaker so they sound the same) It should have a static tone on each speaker one at a time (Fr L, Cen, Fr R, L Sur, R Sur) It would tell you if the reciever can get sound to the surrounds or if it is broken...
