Best surround sound set up for a 2000.00 budget?
Rob2
I'm looking for a 7.1 receiver and surround sound speakers for my new condo. All my speakers will be set up on the wall or ceiling. I have everything pre-wired. Please give me sugestions on what receiver (maybe denon 3805?) and what speakers match up the best with eachother? I would like to find an online store to order from for the best deal.
Username: Kano
Post Number: 361
Depends on how much you want to disturb your neighbours. I'm guessing that you will have to limit low frequency effects, and dynamic range. In that case the Denon 3805 would be more than you would need.
Denon 1905, Harman Kardon AVR235, paired with some quality sattelite speakers would be my recommendation, bookshelf speakers may be overkill. For speakers I think Orb Audio, or Mirage Omnisats might work quite well in your set-up.
FloridaSun
I was just going to recommend Orb Audio too...great stuff!
