Anonymous | Does any know of any good audio test or demo disk that you can buy? Something that like DTS or DD. |
Silver Member Username: Paul_ohstbucksPost Number: 131 Registered: Jan-05 | What? ........to test your DTS? |
Bronze Member Username: TevoChicago, IL USA Post Number: 53 Registered: Feb-05 | Most, if not all, high(er)end audio/HT dealers should have some demonstration disks on hand. If you cannot source them from a local dealer, www.musicdirect.com and www.audioadvisor.com have a fairly comprehensive selection. Chesky makes a number of demo/test discs. The discs for multichannel (DD/DTS) feature test tones, channel effects, etc... the better to impress yourself (or better yet your friends). Hope this helps. |
Moderator Username: AdminPost Number: 240 Registered: Dec-03 | There is a Testing Disc section on eCoustics: https://www.ecoustics.com/Home/Resources/Testing_Discs/ |
Anonymous | Im a dj, so i make my own demo disks. |
