Amp Power
SkieS
Question, I will most likely be buying 2 Klipsch La Scalas rated at 100w/400w peak, and pair them with 2 15" subs rated at 5000w/10,000w(yes, 10, 000!). I am looking at this amp. I don't understand the Ohms thing quite yet, but I'm working on it.
Will this all fit together okay, and piss of the neighbors a little? :D Any other suggestions for amps around the $800-$900 range that may work better?
La Scalas: http://www.klipsch.com/product/product.aspx?cid=6&s=specs
MA Audio 15" Subs: http://www.maaudio.com/productcatalog.cfm?class=263
Blue Ice Amp: ahttp://www.topdjgear.com/tehiblicexam.html
SkieS
No suggestions? Crown also looks very good.
