New member Username: Phrapp
Post Number: 2 Registered: Feb-05
Posted on I am quite happy with my PSBs Image 2bs, but I have been told other names have more bang for the buck. Better sound quality. How does PSB stack up with JAMO, Velodyne, Paradyme and Dalquist? Should I move to a new brand or stick with what I have. |
Bronze Member Username: Stealth_c
Dublin,
CA
Post Number: 88 Registered: Jan-05
Posted on Stick with what you have if you are happy with its sound. Bang for the buck is up to your ears only. |
Bronze Member Username: Tevo
Chicago,
IL
Post Number: 47 Registered: Feb-05
Posted on I would wager PSB speakers stack up well versus any other manufacturer in terms of price/performance. They make some really good speakers. And I agree with StealthC, ultimately, value is in the ears of the listener.  |
jaeelarr Unregistered guest |
Posted on I had a PSB set up about a year ago...it was excellent!!Ive moved to Acoustic Energy and they run about the same in quality.Good choice by the way! |
