New member Username: Adi20_1979Post Number: 3 Registered: 02-2004 | i need a good software preferably free to design a box for the speakers. plshelp |
Anonymous | Page halfway down |
Bronze Member Username: TonytigerPost Number: 14 Registered: 02-2004 | Nice link page. Thanks! |
dfsdg Unregistered guest | is there any specific amount of airspace(inside the box) one ten inch subwoofer should have? I am building a box for four of them divided into four seperated spaces. |
Bronze Member Username: Timn8terSeattle, WA USA Post Number: 38 Registered: Dec-03 | That depends on the mechanical and electrical specifications of the driver, otherwise known as Thiel-Small parameters. Car audio driver manufacturers rarely provide these measurements. Most home audio driver manufacturers will provide them. Once you have these measurements you can use a box software to perform the volume calculation for you. The minimal parameters needed are Fs, Vas, Qms, Qes, and Xmax. |
Anonymous | I need the box spesifications for the pioneer TSW305C/DVC 12" subwoofer |
Bronze Member Username: Timn8terSeattle, WA USA Post Number: 65 Registered: Dec-03 | Google is your friend. top mount depth 5-5/8" sealed box volume 1.2 cubic feet ported box volume 1.3 cubic feet As I stated earlier, the car sub manufacturers don't provide T/S parameters so all you can do is go by their recommended enclosure unless you want to measure the driver yourself. |
Bronze Member Username: RobertinchicoPost Number: 41 Registered: Apr-04 | Timn8ter - there are many DIY SpeakerBuilder magazines available, some have blue prints for simple to complex wood-working projects, crossover projects, car installs and the like. People post their homemade systems in the magazine. Any larger magazine store will have some of these. |
Bronze Member Username: Timn8terSeattle, WA USA Post Number: 67 Registered: Dec-03 | Obviously you haven't seen my website. http://www.alegriaaudio.com |
Bronze Member Username: RobertinchicoPost Number: 43 Registered: Apr-04 | TIMn8thr - thanks for the e-mail; I hadn't see your nice website in fact. I was just trying to offer potential resources for speaker building as I remember making a pair during my teen years; they were hideous): |
john334 Unregistered guest | i need some measurements for 3 solobaric L512 they are going in a two door ford explorer |
Anonymous | how to build a speaker for 150W amplifier |
Anonymous | what would be the measurement for the dash board and to connect the speaker inside the box and what would be the best design of speaker for 150W amplifier |
Bronze Member Username: Timn8terSeattle, WA USA Post Number: 73 Registered: Dec-03 | john334, In almost every case, car subwoofer driver manufacturers do not provide specs for proper enclosure design. The best you can usually do is just follow their recommendations for enclosure size. I have no idea how to answer that last question. |
