my sub sounds better if connected through its crossover than to LFE.does anybody know how cross.in denon avr2800 is set? my guess would be around 80-100hz,which i think is little higher then i would like to,(sub is definitive technology PF15tl+500w,cross.40-150hz/24db)so any idea how to connect it,thank you
LFE bypasses the hpf in the sub. Dont think the 2800 has much if any adjustments to x over in menu. I guess if you sub has more x overs to play with and your not happy the way the 2800 is,run you speakers through the sub and sub to 2800 and use the sub's x over.
