I am about to buy a Yamaha 630W 6.1-Ch. A/V Home Theater Receiver - Silver Model: HTR-5750 630W total power: 6 x 105W 1kHz power rating @ 8 ohms I want to put 3 ceiling speakers in the rear for surround and am looking at the JBL Soundpoint 6.5 2 way speakers. I am going to put one in several rooms so need 3 pair and can get them for 102.00 per pair on the net. Here are the specs below...will they be enough or do I need 100Watts?? Thanks
Sensitivity (2.83V @ 1m): 88dB Low-Frequency Driver: 6-1/2" Titanium-laminate cone with rubber surround High-Frequency Driver: 1" Titanium-laminate dome with EOS waveguide and swivel mount Maximum Recommended Amplifier Power: 80 Watts Frequency Response (--10dB): 40Hz -- 20kHz Crossover Frequency: 2.6kHz
If the speakers are rated at 80 watts max and you have a 105w/chan reciever you may have purchased a bigger receiver than you need. Typically you want to get a speaker with a higher max wattage than your amplifier, otherwise you can run into trouble.
It still shouldnt matter much. It is a lot easier to kill a speaker with too little power than too much. On top of this, speaker makers are pretty conservative about power ratings while receiver manufacturers tend to lie about their power ratings.
J. Vigne
S.C. - You are the cynical one. A speaker rated 20-20kHz with no other spec is hardly conservative. I would say the exageration falls evenly on both sides of the fence.
I cant say im particularly impressed by the frequency response of the JBL but at least they are honest enough to put the -10dB part in there as opposed to just leaving it as is. Besides, I still cant imagine him blowing out those speakers with just a little extra wattage, but I suppose it depends on how loud he likes his music.
J. Vigne
No, wattage of an amplifier is not a determinant of whether you will blow out a speaker. Whether you can hear distortion and have the good sense to turn it down will have a far greater effect on the longevity of speakers. My point was merely that marketing departments exist to impress the buying public. Specs often mean more to the ad writers than anyone else.
So what should I do?? I am going to have 100watt book case in the front. Should I buy the JBL 80w or not?? Will I still have a great sounding system for watching movies if I do??
I forgot to add that I could also by some "JBL Control 26CT's" They are ceiling speakers as well. They are 100 watts but I don't know much about them. Any thoughts would be helpful! Thanks
