Dual sub setup with one sub out
jayb
I'm currently running 2 subs of of a Yammy rxv-2400 by using a splitter for the two signals for each sub (both powered, one seperate, one inside towers) My feeling is that I'm most likely loosing or sacrificing some of the clarity of my LFE due to the splitting up of the signal, over quite a distance I might add.
Can anyone tell me if I'm right and if so what can I do to re-establish full signal quality and keep both subs?
BTW Its not like i'm not happy with my low end, I'm just wndering if it could be better!
