SOUND TOO LOUD
Username: Lucas1v
Hi everybody!!! I really need your help!!!
I have just hooked up my VCR which is a Panasonic, DVD & VCR alltogether, to a Toshiba 46"TV. Everytime I turn the VCR on, the volume goes up beyond my want, and the volume on the TV will not work. How can I fix this?
Please give me a hand
J. Vigne
Go to the menu of the vcr and check for a switch called "fixed or variable" volume control. Its not typical on a VCR, but check that first. You may want to go to the TV menu and do the same.
