Hooking up dvd, tv, vcr,satallite receiver, rf modulator
Loretta
I have a tv with only one cable connection, and I have a dvd player, vcr, satallite receiver, and the rf modulator, the instructions with the dvd player does not specify how to hook up the sat. receiver. If anyone know's how please in laymans terms can you tell an idiot how to hook it up?
If u have 2 antenna ports on the back of the rf modulator then run a cable from the modulator to the vcr then from the modulator to the satallite and from the sat. to the tv last attach the dvd to the rf with the audio video cable.
I have my DVD/CD Player connected with A/V cable. Audio works;Video does not work; I've also got a VCR connected to tv. Does DVD Player have to be on separate channel than VCR, i.e., Player on 3 and VCR on 4 or visa versa or on same channel? Should I unhook VCR completely? I have checked to make sure A/V cable is secure also.
