DVD code
Username: Cg1234
I have a Zenith DVB211C DVD. Does anyone have the code to make it region free? Thanks!
I have a Magnavox MWD200F DVD. Does anyone have the code to make it region free? Thank you.
Username: Myrantz
The Land Dow...
Post Number: 1840
Why don't you post these questions in the DVD Players thread?
Username: Tattoos
DOES ANYONE HAVE REGION CODES FOR A SONY DVP-NC615
OR MAGNAVOX MWD200F
Username: Poppy
DOES ANYONE HAVE CODE FOR LG DV2000 DVD/VIDEO COMBI I HAVE TRIED 314159 but no joy
Thanks
I have a Pioneer DV-343, Regional Settings Code is 1. I would like to chage the regional settings, What can I do?
DOES ANYONE HAVE CODE FOR COBY TF 7000????
does anyone have the code for LG 7622W ? 10x.
Username: Rickyb63
Does anyone know how to fix a problem of WRONG REGION DISK in a TF-DVD7100 model
hotrtcw
Region code hack posted by systemlord, August 02 2005:
This hack also work for the LG DR7622W
Press SETUP
Move down to "LOCK" Symbol
Press "0000000" (Seven zeros)
Enter "0" Region
A "Now zonefree" confirmation message on the screen.
DVD is now Region free.
Good luck!
Does anyone have code for NEXXTECH ESDVD100
DVDXXX
If you're interested, check out the following database of DVD handset codes. It's got a few machines that other sites don't feature, so I'm recommending it. It seems a good place to go for those rarer machines by the looks of things.
It's actually got a Sony unlock on one of its front pages. I don't know whether it works though, as I heard Sony machines can't be unlocked with a handset code? Who knows. Anyway, here's a link to the free page - the codes might be of some use to you.
www.dvdexploder.com/multihacks
Username: Mooner
DOES ANYONE HAVE CODE FOR PHILIPS DVP 530_BK????
Does anyone have code for LG DR6921W???
Langers
Try this, it worked on my LG DR6921W DVD Recorder.
1) Press 'setup' on remote control
2) Move down to the 'lock' picture
3) Press '0000000'
4) Select region code as '0'
Username: Zibawal
Region hack for Denon dvd-1920 and Pioneer 588as?
Username: Vaxtang
i have a QWESTAR (270a4510) DVD PLAYER WHICH IS SET FOR ZONE 2 BUT NOW I STAY IN AUSTRALIA IS THER ANY WAY I CAN RESET THIS TO BE A ZONE FREE OR AT LEAST CHANGE TO MY NEW ZONE CODE FOR AUSTRALIA THANKS FOR ANY HELP.
Just bought LG CX440 DVD/Video Combi in Qatar. Does anyone have the code to make it multi-zone?
Thanks
dangerouso
superstar!!!!
Smoke was coming out of my ears after buying the DR6921w and getting the so called codes from bing lee!!! this code for the player worked a treat!! thanks alot Langers!!!
Username: Gervasio
Hi. I was wondering if there is a dvd region unlock for coby TF-DVD7100 end DVD car Jensen VM9510 ?
hi all,
is there a code for the lg dr7622w that will make it possible to copy a movie from another dvd? I meen a movie that is protected ofcourse.
Thx
langers thanks your code worked on my LG DR6921W until now it seemed I had a machine as useful as a Beta Video Player
Sara26
Hi,
I'm here again with a question about the LG DR7622W. Is there a code that lets you set the region - not just puts it on region 0? Thanks.
Sara
i have the lg dvd recorder (dr7622w) and i can't play mpg files on it.
cAN SOMBODY HELP ME PLEASE!!!
Username: Need_some_help
ReykjavikIceland
Got a PHILIPS LX3600D Could some one help me unlock it so I can stay warm at home in Iceland watching DVDs I just bought in the States? please answer to mani@atlanta.is
1000000 thanks
QZN
Does anyone have Curtis DVD 5028 P Unlock codes?
Hi Guys, I have a Philips LX3600D DVD Home theatre system. If any one can belp to break the region code in the same i would be grateful. Please mail to santosh@focuzcomputers.com
Nobody
retrieved from http://www.dvd.reviewer.co.uk/forums/thread.asp?Forum=176&Thread=512969&Type=1&N ewPosts=1
I found that this hack works for the Prism TF-DVD7100 Portable DVD Player. I found it on a US website where the brand was actually called COBY rather than PRISM.
With no disc in player:
On the remote control:
Press Setup
Press FF
Press FR
Press Next-Chapter
Press Prev-Chapter
Should now display a code above the language selection
Press the RIGHT arrow until the end figure is 255
Press ENTER
Press Setup to finish
It seems you only need to do it once as well!
AlienGurl
hai... been searching for a crack into a MAGNAVOX MWD 200F DVD player, using the remote. i know there is one, but i cant find it again. would someone please run thru it for me right quick? i would be ever so grateful!^.^
Username: Surf2609
Durban, Natal South Africa
Anyone got the unlock code for a portable Samsung DVD-L75.
Many Thanks email to daffodils@mail.com
Peublo
Does anyone have a region code for NEXXTECH SUPER-SLIM PROGRESSIVE SCAN DVD PLAYER 1617007?
Hi people
As a lot of other pelople I bought a Maganavox MWD 200F in USA hopping to a hack code at least for region 4 (Brazil).
Somebody in the forum has this code?
Thanks for send me it.
e-mail: edclsilva@uol.com.br
BR
astroboy
langers your a champ mate.Got a lg dr6921w,code worked a treat.Cheers
I have a NEXX tech DVD system and Direct T.V. system , some how I think the Direct TV remote reset my NEXX TECH ESDVD100 player region code
does any one no how to reset it
j ai un probleme avec mon dvd enregisteur LG DR6921 j entend que le son mais l image n apparait pas je crois que c'est un probleme de code pouvez vous me donner le code pour le remettre a zero inzirorera@hotmail.fr
Username: Sidtwat
i also have the magnavox mwd200f if somebody has the hack code could you plz plz plz send it to me as im desperate could you send it to yeah_a_know21@hotmail.co.uk
Username: Killedrum
Hello! I have Sony Rdr-hx710s dvdr/hdd player and I would like to make it region free. Can you please send me the handset code for the player so that I can make it region free.
Username: Killedrum
Can someone give me the handset code for my Sony Rdr-hx710s dvdr/hdd. Send it to my email: killemh@jippii.fi
Username: Suzanne2000
Wallaroo, S.a Australia
does any one know what the code is for dvd player LG V8824W is so i can watch any reagion dvd thankyou and how do u put in the number to unlock it so u can play any region dvd as well thankyou
Username: Pastordatsu
does any one has the code for making the lg dvd player to play vcd?
Username: Sandecker
HI THERE DOES ANYONE KNOW HOW TO UNLOCK AN LG DV8600 MODEL TO PLAY REGION ONE DVDS????
CAN ANYONE HELP
Username: Carlosh
Tij, Baja california Mexico
Hi does anyone has the code to unlock a Sony dvp-cx985v
Username: Britnla
Can can obtain an ebook at www.thedvdunlocker.com where you can see if yours is listed...
Username: Paine
Does anyone have Philips DVP 532K Unlock codes?
Username: Britnla
1. power player on
2. press setup
3. scroll to preferences using the arrow buttons
4. enter 1,3,8,9,3,1
5. use the up/down arrow keys and select the region you want... ie: region free is 0 (zero)
Username: Nicosev
is there anyone who knows how to make my pioneer dvr-440h to be all region
Username: Trevturtle73
Hi all,
Here is one from left field.
I have a LG DR6921W (yes i know its old, and I know its a peice of junk) that I picked up at a garage sale for $30. I can get it to play audio CD's and VCD's, however it will not play any DVD's. I am in australia and it is currently set at region 4, I have tried Langers 000000 unlock code on region free (0) and they still dont play. the following error comes up when I attempted to play a DVD "unknown disk, plse check disk again" not sure why, maybe the laser is broken, however it still plays vcd and cd's - very strange.
Has anyone experienced similiar problems, or can anyone offer any help on this subject. Any suggestion would be appreciated.
cheers
Trev......
Username: Larry_r
Naples, FL
Post Number: 1799
Sorry Trevor, but this belongs on DVD Players under "Home Video" - where more code-people will read it.
Username: Nuck
Post Number: 6450
8675309
Username: Zooter
hi, does anyone have the unlock codes for an LG DW7531p? thanks
Username: Loki123
need the hack for magnavox msd126...
appreciate any help
tnx
Need to Register?
Forgot Password?
Enable HTML code in message
