Building system around Thiel 1.5 speakers
Username: Mgarrett
Cincinnati, Ohio
I've recently come across a used but excellent conditin Thiel 1.5 speakers. I'm looking for some advise on building a system around these speakers. I intend on playing vinyl and CD's.
The speakers recommend power wattage at 150, I believe.
So, Pre-amp with amp or just amp? Maker? spec's? good buys on used equipment? etc.
Jasdeep
Hi Mark,
I dun know about your budget but i would like to ecommend you following componets :
Vinyl :
Rega Planar (any one which falls in your budget)
CD Player :
Creek CD 53 SE
Integrated Amplifier :
Creek 5350 SE
This is a cracking system...If you can afford definitely go for Bel Canto eVo 2i Integrated amplifier.
You can also go for Krell SACD Standard CD Player & Krell 400Xi Integrated if it is in your budget
Regards,
Jasdeep
