Kim Williams Unregistered guest |
Posted on What is the difference between these 2 models? For the same price, is there any other model you would recommend instead? |
Posted on E90 = 8inch dual woofers. E100 = 10inch dual woofers. Not sure what price you mean as they are not the same price and it also depends on where you are getting them from as well |
ArmchairQB Unregistered guest |
Posted on What do you mean when you say it depends on where you are getting them from? |
