Odd receiver question
pats22
Are there certain receivers that run "hotter" than others?
I ask because where I am placing my receiver I have plenty of space above and behind, its just the sides that will be very close to the walls of the entertainment center
thanks
Username: Mike_6289
Post Number: 7
you should be fine... receivers dont usually radiate heat from the sides unless theres a fan on the side
