HT speakers for HK 335
Username: Nilpil
I'm planning to buy HK 335 receiver. Could you please tell me which HT speakers I need to consider. whether I should buy infinity 450 or Paradigm Cinema 70 Or any other speakers which I need to consider.
My budget for speakers is 500.
HT will mostly used for light music and movies.
Username: Sinkdrain
Post Number: 120
Try the Athena speakers available at Best Buy. Athenas are bright and detailed and match great with the warmer H/K. You should be able to put 4 AS-B1 bookshelves around the room and one AS-C1 center for around $500. The Athena Point 5 speaker set is also nice.
Paradigm, while nice, may be too warm for your receiver and I never really liked the sound of Infinity speakers.
Check out those Athenas...they sound great with H/K
