Pioneer 812K or Yamaha HTR-5660 or Onkyo ???
itshuman
Hello everyone,
I bought Onkyo HT-510 speaker set. Looking at cnet reviews and listening to it, it's sound is decent and good for me.
http://reviews.cnet.com/Onkyo_SKS_HT510/4505-6467_7-30422543.html?tag=topprods
Now i plan to buy a receiver. I got Pioneer VSX-D812K . It has options to setup speakers by comparing the sound, input for feeding in the distance for each speakers other than other dolby blah blah features. Reading thru forums, pioneer is not the best choice for many. I tried to search and found yamaha HTR-5660 or onkyo 501/601 in simlar price range.
any thoughts/feedback will be helpful in my decision making process.
thanks
itshuman
I looked at the D812K because it has all-channel pre-out outputs, a feature only available on much more expensive features in other brands. But I can't tell you how any of them sound, sorry. The D812K sure has a lot of features for the buck!
sarandon
i head both the yamaha and the onkyo. i do like yamaha but i will have to go with the onkyo. it has a smooth yet powerful sound. i would also try the marantz receivers.
