Bronze Member Username: Disco_stanPost Number: 67 Registered: 12-2003 | Im looking at 2 highly recommened recievers NAD T742 and the HK 330. This will be my 3rd upgrade in the past 2 years and I want this upgrade to last! Right now I have Fluance speakers and Subwoofer to start off with, nothing special. I Found this deal and a website..http://www.spearitsound.com/nad/dynamicduo.asp looks like a bonus deal... So any help to narrow this decision down will be great. I wanna stay around...500 to 900 dollars and any other recommendations will be great too. Thanks |
Bronze Member Username: JonmoonPost Number: 64 Registered: 12-2003 | Matt, see Saturdayaudio.com They have the T742 at $449 and the T512 at $199 with a deal to take $50 off if you buy both for a price of $599 for the both. www.saturdayaudio.com/t742.htm Same deal (though the T742 is refurbished) at: www.dmc-electronics.com/AllProducts.asp |
Bronze Member Username: Disco_stanPost Number: 69 Registered: 12-2003 | So what would be the chances of me getting a faulty one..or do I not ahve to worry about that with the newer makes? |
Silver Member Username: GmanPost Number: 195 Registered: 12-2003 | As long as it has the original warranty there is nothing to worry about. |
