Minimum safe ventilation area above amplifier?
Username: Maxximtl
Denver, CO. USA
I've got a Marantz PM-7200 that is currently residing in a fairly tight area. Due to the mounting location, I have to have a smaller component sitting on top of the amplifier. While I realize that it is far from ideal, is it safe? Will the amp. get enough ventilation in this setup?
Just for reference, it'll be driving a pair of 8ohm speakers in A/B mode.
Username: Ca_convert
CardiffUK
Post Number: 109
If you live in the US then the Safe Height Above Toroids (S.H.A.T.) is about 3.12mm which should prevent embarrasment from thermal cout out.
Howvere, in Europe; its likely banned under the kyoto agreement (he he how may readers recognise THAT treaty eh?), so you will have to run it in Class B mode only.
In Asia, you can do what the chuff you want. Either way its fine unless it overheats, which case it will stop working: then you will know to move it!
nout
The amp can get pretty hot so I wouldn't put anything on top of the amp, the Marantz "user guide" says clearly:
- Make sure ventilation holes are not blocked or covered
- Ensure that air can circulate freely around the amplifier.
This amp can run pretty hot so I'd follow Marantz's advice
However: My dad owns a (crap) Sony receiver for 10 years already, placed on top of it a Sony cassette player (12 years old) and a cd player (15 years old). The bottom of the cassette deck is always hot, for my dad never shuts his set off.
It never failed to work!
