New member Username: BjmoorePost Number: 1 Registered: Jan-05 | I just got rid of my dvd/karaoke player and have been looking online for something else to plug my microphone into for my home theatre system. What can I do? |
Gold Member Username: Project6Post Number: 2651 Registered: Dec-03 | You just got rid of your karaoke/dvd player. Why do you need to use a microphone? |
New member Username: BjmoorePost Number: 2 Registered: Jan-05 | Sorry, I guess I should have elaborated more. I was upgrading my dvd player and thought there were components out there to plug in a mic. I still want to be able to have the karaoke capability, but I have been unable to find a separate component with mic inputs. |
Bronze Member Username: Usa2k4Post Number: 64 Registered: Dec-04 | If you're in the US, get this microphone adaptor at Radio Shack for ~ $15: http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&category%5Fname=CTLG%5 F007%5F006%5F001%5F000&product%5Fid=32%2D1254 . |
Gold Member Username: Project6Post Number: 2665 Registered: Dec-03 | I think you should still go with a separate karaoke machine if you really enjoy the hobby. JVC makes some of the good ones. I separate the karaoke machine from the other components ![]() http://www.karaokewh.com/jvc-karaoke-players.cfm |
Bronze Member Username: Usa2k4Post Number: 66 Registered: Dec-04 | I bought a Pioneer MA-9 long time ago for $150 at a local store. This is a pretty good Karaoke processor that has key control and you can use it with any player. I think you can get it cheap from E-bay. |
