New member Username: Rob7TUCSON, ARIZONA USA Post Number: 1 Registered: Jan-05 | Poked around the different categories a bit and tried this question at another forum but had no luck. Looking to run audio to the patio, master, and garage/game-room through a speaker selector (music only). I have seen some that say 100 watt RMS and others higher. Going to try to run a Sony DA5ES receiver to the selector. Does a speaker selector change, add to-take away from, the sound? Looking for any comments or suggestions on this. Also, will 16 gauge wire work for the rear channels (6.1) on surround with 8 in. in-ceiling speakers from the same receiver? 40 ft run absolute max. I'd appreciate the help. Thanks |
J. Vigne Unregistered guest | 16AWG will be fine. See if this link helps. https://www.ecoustics.com/electronics/forum/home-audio/119086.html |
New member Username: Rob7TUCSON, ARIZONA USA Post Number: 2 Registered: Jan-05 | Thanks for the info. |
