Denon 3805 vd ohms
Can the denon 3805 drivr a 4 ohm speaker?
Username: Project6
Post Number: 2614
check page 16 of your manual
Do not have it yet. Need to know in order to buy.
If you know the answer and do not want to give it just do not say anything, slence is most often wise.
Username: Project6
Post Number: 2618
here is the page
http://www.usa.denon.com/catalog/pdfs/AVR3805%20DFU.pdf
page 16 is a warning about impedance and page 101 tells you about the power rating if using 4ohm speakers.
It's a teach a man how to fish kind of thing, so don't cry. At least I don't hide behind the wall of anonymity.
It is good that you are trying to do some research, though.
Not crying. But you can keep your arrogance to your self. If I had said Berny answer this for me then I guess you could give me your useless answer (first response) But I addressed an entire forum. If you do not have a kind word say nothing. your second response is more appropiate as it is indeed helpful.
Username: Project6
Post Number: 2622
But did you learn how to fish?
Did you learn how to think?
Username: Project6
Post Number: 2629
Still hiding behind anonymity, huh?
ha ha ha
I believe I'm in a similar boat with anonymous. I have a 3805 connected to a Left, Center, Right speaker setup. My speakers are 4 ohm rated. In looking at pages 16 & 101 I don't really get a definitive comment from Denon.
My question is, do you believe the 3805 is an appropriate receiver to couple with 4 ohm speakers?
If not, what receiver setup might you recommend?
I have more money tied up in the speakers than I do in the 3805.
Thanks in advance.
Thanks in advance.
Username: Gavincumm
Post Number: 83
anon... I really wouldn't insult benry
he's one of the more knowledgable people in the forum.
if you want a better answer, post in the APPROPRIATE section (IE amps / recievers)
gavin
Username: Frank_abela
Berkshire UK
Post Number: 368
Anon
I can't believe your cheek! Berny gives you an accurate answer, even though it should be in another forum. Given your lack of *any detail whatsoever* in your first note, it's reasonable to assume you might own the kit. Then, when you respond tartly, he still obliges with the manual OFF THE INTERNET (and you could have found if you had a modicum of sense) and you keep insulting him!
You are one sick individual. Go away, but if you must come back use a name - I suggest D1ckh3ad would be appropriate.
Frank.
Frank and Gavin
Was looking for the section for the Idiots and your names came across. This is an insult. What I told Mr Barney was not.
Berkshire UK
Post Number: 380
Anon (peek a boo)
What you said to Berny was unacceptable. Learn your English and re-read your posts.
Frank.
I said nothing insulting to him. If did not want to answer he should have done just that: not answer. Anyway, why waste time with you. You do not bring nothing useful.
Dissmissed.
Username: Gavincumm
Post Number: 87
lol... this makes me feel like I am back in grade school. I personally think that the forum should require everyone to register to get rid of people popping up like that.
How hard would it be to register if you have a serious question?
Jonas Balducci
Here's the answer:
http://www.usa.denon.com/support/faqs_ht.asp#Q9
Enough bickering already.
Berkshire UK
Post Number: 385
Anon
Like I said, re-read your post, you twit!
Come to think of it people, I think Anon is just a troll so it might be an idea to simply ignore the ignoramus.
Frank.
