I'm adding a phono stage to my Cambridge Audio A1 mk3. What techical expertise & equipment do I need to install a Cambridge Audio PM01 PRE-AMP stage to my amp? Basically, what do I do? Help! There's a heap of vinyl screaming to be played here!
If it's an external one, then you simply connect it between your turntable and amp, through the phono-input. If it's an internal upgrade your'e having, I believe your dealer will have to send it off to Cambridge Audio to have it fitted.
Whatever, talk to the dealer from whom you purchased the A1.
