New member Username: Json717Post Number: 1 Registered: Jan-05 | I've placed an order for Monitor Audio Bronze series speakers. B4 for front and B2 for rear. Using 60/40 for Music/HT. My room is an open living room 16X24 with catherdral ceilings. WOuld not be playing very loud since I have 2 small children in the house. Music preferences are vocal jazz, alternative, and popular. Looking at the Marants SR5500? Any thoughts would be appreciated! |
Silver Member Username: Riches1Atlanta, GA US Post Number: 134 Registered: Apr-04 | That's a good choice. If you like the Marantz, you might like Harman Kardon as well. Check out www.hifi.com for Marantz prices and jraudio.com or onecall.com for good prices on H/K. |
Silver Member Username: FalpPortugal Post Number: 132 Registered: Mar-04 | Marantz and MA are one the best matches! Great choice. |
Silver Member Username: BilldashillPost Number: 149 Registered: Dec-03 | Marantz will probably strain a bit, might even overheat if pushed a little too hard. Make sure you have proper ventilation or even a small fan to move the airfrom the top of the receiver. Otherwise, its a very good match. |
Silver Member Username: FalpPortugal Post Number: 133 Registered: Mar-04 | Marantz has better real power ratings than any other receiver in it's class. I've heard the SR5400 (same chassis, same amps) with 5 87db speakers (need twice the power) and no strain at all... |
