Unregistered guest | Hi, New here and not even sure how I got here. So, if you could email me direct I do not if I will ever find this again. Question: I teach Dancing and I want to use my IPod for classes. Is there a speaker system you would recommend that would be small but powerful? I have seen the systems that you drop the IPod into and I will take advice on those but I wondered if there was an amplified small speaker, small being no bigger than 6 inches tall, that I could hook the IPod into. I have a JBL amplified speaker but it is 2foot high and heavy.... and I am not even sure I could hook the IPod to that. Please advise by email debbieramsey2000@yahoo.com Thank you Debbie |
Tony Mac Unregistered guest | Check out the reviews section of www.ipodlounge.com You should be able to find some great info there! |
SPECIAL K Unregistered guest | PLEASE HELP............I Download music from limewire and they are saved on my PC, how do I upload to play on my webpage...? Is there a site where I can put in the file location and it generate a code...? |
New member Username: HammondrckrPost Number: 1 Registered: May-05 | I dont have an ipod but I have a creative and I just get a small headphone jack to an rca and just plug it into an aux input thats worked for me in the past ~alan |
New member Username: MediconePost Number: 3 Registered: Aug-05 | Debbie, check out the Cambridge Soundworks Model Twelve. This is small discreet components that sets up in minutes and you have a line-in that you can feed a docked iPod into. The sound is excellent and it has two very small but effective bookshelf speakers and the carrying case is also a subwoofer. The sound can easily fill a room with sound. I use one on my boat and it overcomes the sound of a large diesel engine so it should work for the dancing classes. About $399 from www.musiciansfriend.com |
Unregistered guest | i connect my ipod to my guitar amp. i crank the hell out of it and it sounds good, but can this harm my ipod? |
