HelpWanted Unregistered guest | I have the Onkyo TX-SR702 receiver and a new 42" HDTV. The space is 15x25 (in feet). I'm looking for a 7.1 configuration of speakers, 2 of which I would like to be in-wall (surrounds L&R). I have a budget of $2-$3K. |
GoodSpeakers Unregistered guest | Try Axiom speakers I here there good. |
Bronze Member Username: DlowemanPost Number: 59 Registered: Nov-04 | Onkyo would sound very good with Paradigm. Check out the monitor line and the Studio line. You could probably get the monitor 7's, the cc370, adp370 surrounds with the minimonitors for rears and a nice sub. For a sub I would say either a paradigm or, I have an Hsu sub which is awesome and are fairly cheap. |
Gold Member Username: Project6Post Number: 2565 Registered: Dec-03 | for that budget, try this http://www.ohmspeaker.com/ |
edster922 Unregistered guest | Check out ascendacoustics.com and click on "System Advisor" under the purchase menu for the best package deal. |
New member Username: Blslim352SAN ANTONIO, FL USA Post Number: 1 Registered: Jan-05 | novice....helppppp!!!!how do you attach speakers(cheap)to back of tv??? |
New member Username: Paul_ohstbucksPost Number: 7 Registered: Jan-05 | Im not sure I know of any TVs that allow that kind of direct connection. It's probably for good reason though because if you found a way to do it, it would sound terrible because your TV doesnt have the necessary power. |
Gold Member Username: Project6Post Number: 2590 Registered: Dec-03 | Bonnie, You really should start your own thread and not hijack this one. It is rude! |
HelpWanted Unregistered guest | Any ideas about in-wall speakers? The way the room is setup, there is a walk way is to the left of my sectional and a wall on the right. So I was thinking about in-wall speakers in these spots (L&R surrounds). Good/Bad idea? Other ways to go? |
Bronze Member Username: NuckParkhill, Ontario Canada Post Number: 29 Registered: Dec-04 | Help, Cadance hace a wide choice of build ins. |
