Radio always heard on Center Channel Speaker
Vikings
I can always hear the radio (station uncontrollable) on my center channel. I have an Onkyo TX-SV595 and no matter what input is selected or how the volume is adjusted or what radio station is selected, there is always a faint radio station coming through, on only the center channel. I tried the powered and preout outputs and they both do it. Should I try to have it fixed, or do I need a filter somewhere? Thanks.
Username: Kano
Post Number: 270
It may be the receiver, try unplugging any antenna or cable from your receiver to see if it either changes to static or disappears altogether.
If not you may benefit from running your receiver's power through a line stabilizer/conditioner.
http://www.furmansound.com/pro/pwr_cond_seq/Index.htm
