hi all, I need an advice. I'm just upgrading my ht system and i can't decide between the two amps in the subject. I will use it for music and movies 50%/50% with jbl northridge e100 as main speakers and jbl e20 / e25 as surround speakers. I'd really appreciate your opinions. Thank you!
As the jbl's are on the revealing side, matching them with the HK would probably be your best bet, but listen to them with both and see which you prefer.
Gianluca Tarei
Thanks. Probably I won't listen to denon with jbl ( I can't find anyone who has both), but if the other combination sounds good, it will be mine!
