This is it spec.. DTS 5.1 ch, Dolby Digital 5.1 ch, Dolby Pro Logic II 5.1 ch decoding 3 Active EQ mode 5 DSP listening modes Digital AM/FM tuner: 40 presets Remote control unit (with the capability of controlling Kenwood DVD Players) 2003 new generation stylish flat board design & easy unit operation Surround power output: 100W x 5 (FTC, 8 ohms, 0.7% THD) Terminals
3 digital inputs (1 optical, 2 coaxial) 6 audio inputs (including Phono MM and 6 ch input) 2 Audio outputs 3 visual inputs 2 visual outputs Subwoofer Pre out 6 ch input for DVD Audio reproduction
Amplifier features
24-bit Cystal DSP 24 bit resolution D/A, A/D converters 96kHz/24 bit audio reproduction capability Midnight mode (Dynamic compression system in Dolby Digital mode) Independent speaker level control adjustment 2 AC outlets Loudness control Bass boost Full Auto Digital Analogue Input Selector Set up memory for each channel/Input sensitivity control (Input level adjust by 3 steps) Digital REC mode: Auto/Manual Display dimmer function Dimensions and weight
i had the kenwood vr-6050 and i did not like the sound of the receiver, although i should have gotten the vr-6070!! but anyway kenwood makes a good receiver for the money, but their are some better choices out there. plus i can already tell you that you will not like the 3 Active EQ mode and the 3 Speaker EQ mode. they make the sound so dull. But you will like the Circle Surround II modes it has, to me i like it better than DPL II! oh and the 5 DSP listening modes suck a$$ bigtime!!! i know there are 5% of people including me that uses the DSP modes that a receiver offers. If you like DSP modes then i would recommend yamaha for dsp. since the invented them back in 1986.
