i would go with the paradigm mini monitors, IMO they are miles ahead of the ones mentioned.
edster922
You might also want to check out the Ascend Acoustics CBM-170 ($340 shipped) and CMT-340 ($566 shipped). Those are USD though.
Just auditioned both last weekend, very impressed by their accuracy in the mids and highs.
rayt
Energy C-3, no contest
I just bought the Energy C-3 after listening a whole weekend to a whole bunch of speakers.
Paradigm Studio 20/40, Monitor 3/5/7, PSB Image 45/65, B&W 600 series, and Boston Acoustics. I really like the Studio series, and the Boston Acoustics, really clean sound, but the Energy C-3's came awefully close to their quality for half the price, especially in their clarity. Excellent value those C-3's are. And they are so good I am considering getting a second set for my other room.
Personally, the Axiom speakers I've heard so far, I was NOT impressed at all. Even if their current ones are better, I'd rather not take the chance.
I just returned the Axiom M22Ti after 2 weeks of auditioning them. Give Paradigm Monitor 5 or Studio 20 a try, based on your budget. Also check out the B&W 602.
ltlsause
The company that owns athena and energy makes there poducts a great bargan. The energy are better than the athena ( I have tried both)but then again the athenas are less than half the price. Energy if you can spend that much, athena if you can't
