Bronze Member Username: DarySao Paulo Brazil Post Number: 33 Registered: Apr-04 | Thanks in advance for any suggestions to where I can get the AVR-430 service manual!!! Needed to solve setup memory failure. Already tried Harman and local representative. Thanks again for any help. |
Silver Member Username: KanoPost Number: 250 Registered: Oct-04 | http://manuals.harman.com/HK/Owner%27s%20Manual/AVR%20430%20OM%20FINAL%20(REV%201-5-04).pdf |
Bronze Member Username: DarySao Paulo Brazil Post Number: 34 Registered: Apr-04 | Kano, Thanks, but this the owner's manual. I need the SERVICE manual. Or at least some directions to where is located the setup memory power circuit. HK support says that a special capacitor needs replacement. Regards. |
Bronze Member Username: AfrogtPost Number: 21 Registered: Dec-03 | The 430 can't be 2 years old. It should still be under warranty. Why not just send it in for repair? |
Bronze Member Username: DarySao Paulo Brazil Post Number: 35 Registered: Apr-04 | Hi Greg, The unit has been bought in Brazil, where we get only 6 months warranty. Also, there is no local service center. I could send it to America but shipping costs and customs papers could exceed unit value. Thanks anyway |
Bronze Member Username: DarySao Paulo Brazil Post Number: 37 Registered: Apr-04 | Any ideas?? The e-mail of a service center may help! Please... |
dkendall Unregistered guest | http://manuals.harman.com/HK/Service%20Manual/AVR430-630%20sm.pdf That was the first hit on google for 'AVR430 Service Manual'. I assume you didn't try very hard to find it. ;) |
Bronze Member Username: DarySao Paulo Brazil Post Number: 38 Registered: Apr-04 | dkendall, Thanks a lot!!! You wouldn't believe how many times I tried this search on Google! I even tried to modify the URL to the user manual, assuming service manuals URL could be the way you found out... but didn't have your luck. Regards. |
