Fluance or Athena Mirca 6 (HTIB)
Username: Nutopia
Post Number: 14
I'm looking at these two different speaker sets:
athena Technologies Micra 6 Home-Theater-In-A-Box (HTIB) (~$550.00)
or
Fluance SV-10 + SV-6 + AV-SC (~$500.00)
Any recommendations between the two? I'm leaning toward the fluance.
Username: Project6
Post Number: 2349
Two different classes, too. But I would recommend the Fluance over the Micra 6.
Username: Nutopia
Post Number: 15
What do you mean by two different classes, exactly? I'm a novice, I must understand...
Thanks!
Username: Project6
Post Number: 2398
What I meant was, you really can't compare the Micra 6, which are bookshelf speakers to the Fluance's SV10, which are floor standing towers.
Username: Semicycle
I just purchased a Pioneer Elite VSX-52TX Receiver and I plan to match them up with the **exact** same Fluance speakers you mentioned. The reciever should be a good match since it is designed to push bi-amp speakers using the extra surround channels. Good luck mate.
