Athena AS-R1 Speaker Stands
PaulM
I recently purchased a sourround sound system including Athena as-f1's, as-c1, and as-r1's. I'm trying to find some decent adjustable stands for the AS-R1's. I tried this incredibly overpriced set from BB, "http://www.bestbuy.com/site/olspage.jsp?id=1051826211561&skuId=5423687&type=prod uct", but they are too flimsy. The speakers weigh about 10lbs, and I would like a pair that look similar to the ones from BB. Any ideas, suggestions?
Username: Classical
Los Angeles
Might consider building your own like I did. It's an effort to build, but after seeing how flimsy the store bought ones were, I decided to go for it. The most difficult part is finding a place that sells lumber and has a cutting facility to saw the wood you need to your own specified size. After that, some sturdy angles, some screws, black spray paint, and you're done.
PaulM
My wife you shoot that idea down. something about decor...I'm not sure, wasn't really listening.
Username: Project6
Post Number: 2350
Try Sanus
https://www.sanus.com/cgi-bin/web_store.cgi?page=products/furniture/platinum.htm l&cart_id=
PaulM
Those Sanus stands-- how sturdy are they? They have a 10lbs wight limit, which I would be right at. Has anyone put these rears on a stand, and if so, what one?
