Your thoughts on best 5.1 Receiver for under $300?
Username: Mercuryseattle
I've really enjoyed reading the forums and would appreciate people's thoughts.
I'm looking for what people think is the best value in an AV receiver for a 5.1 system. The room was pre-wired for a 5.1 system, so I think I'm just going to live with that. So I don't think it makes sense to spend money on some technologies since I will only be using 5 speakers (plus the sub).
It will be used with a low to mid-range set of Boston Acoustics speakers that were purchased in 2001.
I would like to spend under $300, and would definitely consider a refurbished system.
FWIW, I am installing a full home theater in the basement, so the serious gear (and funds) will go downstairs.
Thanks for your consideration.
Bill
